El Jefe
Which unlock program are you using? very clean..I like it.
That's Widget locker. I highly recommend it. Very customizable, especially after the last update.
Which dock are using? I'd like to have my gmail have the unread messages pop up. Any detail would be appreciated.
Xiang, Dude your setup is super slick! Could you run through your setup?
haha thanks. So some of the more important programs im using is widgetlocker 2.0, beautiful widgets, Glass2 icon set, wallpaper and dock from honeycomb using Launcherpro, note widget is Simplenote!. I'm running apex 1.4 with the revolution theme.
How do you get the date, time etc. like you have it on your lock screen?
Its an app called widgetlocker. Once you have it just long press on any empty space and you can add any widget like you do on your homescreens.
Yes but how do you make it look like you have it? I can place the date and time widget but it does not look like the way your lock screen has it with the block of text. I cant find the option to make it look like that.
