boyer61
Geolocation is not working for CM7. Thats the only thing i can find wrong with it. I always wanted just the clock on the homescreen, and not the clock and the weather. lol
From time to time I've had that same problem with LP. Give it time, we're still not to a final release, this is just an RC. I expect things like this to be pretty well ironed out for the final.
Yeah, I've had it before but its been a long time. And if it were just launcherpro I'd use ADW, buuut it's both :/
I even turned on the "lock in memory" option and it still doesn't work right. Meh, any ideas? Any tweaks I can do?
Is noone else's doing this?
Loading a custom kernel has made it work great for me. It was the Cyanogen kernel clocked to 800MHz that I experienced that problem with.
I am currently running Chevy No. 1 ultra low voltage, 1.2GHz kernel. I run it at 1GHz typically and haven't had the laggy/force close launcher issue.
The numbers indicate the cap. You can use either, just adjust it with setcpu. If it's unstable, load the low voltage version.Should I download the ultra low voltage 1.0 ghz, or the ultra low voltage 1.2 ghz and adjust it with setcpu? I've never changed my kernel.
Flashing a kernel is just as easy as a ROM.
Put it on the root of the SD card, reboot into recovery, and install zip!
One problem im having, Beautiful widgets can't geolocate me for my weather. although maps and latitude is showing my exact spot?
Ok, loaded up chevyno1 1.0ghz ultra low and things seem to be running really smoothly. woo!
Thanks a lot caliber!
My BW geolocation is working fine, GMaps too.
Trying to do my first root and I am having an issue. Following this link
Motorola Droid: Full Update Guide - CyanogenMod Wiki
I get to these instructions
# Open the RSD Lite program by right clicking it and selecting Run As Administrator.
# Click on the "..." button next to the filename box and select the .sbf file.
# Once it is selected, hit Start and wait for it to finish flashing the device.
When I click... I find the sbf (named MC1_A855_1282081087_Recovery-Only_SPRecovery_0.99.3b but I can not click start.
What am I missing??
What am I missing??
Are you trying to root or return the phone to its original state?
You didn't extract the SBF...it should be named MC1_A855_1282081087_Recovery-Only_SPRecovery_0.99.3b.SBF
