Battery Drain Issues & Resolutions
dmark44
842
I had it checked to avoid poor connections. This is an all of the sudden thing though. I've had the phone for two weeks and this is the first time cell standby is chunking down my battery life. Reset didn't work, might just factory reset for fun.
I've had the same problem for about the last 4 daysv with my Moto X Pure. I have also had the avoid poor WiFi connections setting checked, but it has been that way since I've had the phone.
I'm going to try to reboot and see if it helps. Statistically, cell stand-by doesn't look bad as a percentage, but I don't think it should be on so much (as a top 3 or 4 battery drainer even when I'm on WiFi.)
beeare
491
This is what I got yesterday with about 2.5 hours of YouTube and everything turned on. I'm content with this. With normal usage I should never be to charge before the end of the night. And that's pretty much all I ask for.
Masheen
499
10
Re: Battery Drain Issues & Resolutions
The way I eventually fixed this was by switching location from high accuracy to battery saving mode (unless using gps). The DT2 has a very aggressive LTE radio, and it will try and hold LTE in areas where we really should be on 3G bc the LTE speed isn't attainable anyway.
Note that this cell standby drain/ mobile radio active doesn't appear when there is a strong LTE signal even with high accuracy selected and allow scanning turned on
dmark44
842
You're right. I did the same and the last 3 hours have been a noticeable improvement.
18t
759
How do you get to the process stats page? Can't find developer menu!
You have to tap on the build number several times consecutively to unlock the dev menu. Settings -> About phone -> Build number -> taptaptaptap...
DonGreyface
9
I just got the DT2 last night after shattering the screen on my DT1 Sunday night. So today is my first full day of use, and I am a little disappointed right now. I have 38% left with just 2hr35m SOT. I'm using it the same as my old phone since I don't have to get used to a new UI and my DT1 would only be down to roughly 65% by now. I'm hoping I didn't get a bad phone. As a matter of fact my battery dropped to 36% just while typing this. And ideas? I don't seem to have a rogue app and all other settings are how I had them on the DT1.
Masheen
499
10
Understood. But you gotta post battery stats from GSam or Process Stats so we can help.
Masheen
499
10
Since I just downloaded GSam I don't have an accurate reading on that.
Unlock developer options in settings by tapping build number until it unlocks then the 5th selection from the top is process stats. Click the hamburger menu and set duration to 24 hours and post that ss
Masheen
499
10
Next
Ok the one thing pro stats doesn't show is screen on time and cell standby. Use the regular battery stats menu and post the first screen then click on screen and post that, then click cell standby and post that.
The app usage looks normal, however I'd look into disabling some of the Verizon bloat if you haven't, I made a nice post in this forum on which ones are safe.
DonGreyface
9
Is this what you're wanting? I have the rest of the list but for some reason can only post 1 pic at a time. Sorry for the ignorance on how to do this.
DonGreyface
9
And for good measure. BTW, the signal has always been the same for me no matter the phone because of where I work. And I've always left WiFi on. Plus I always disable verizon bloatware.
