droid turbo
carla3610
4
I've had this phone for 3 weeks and my biggest complaint is that people I talk to say I sound far away or that I sound like I'm talking through a tunnel. I do not use speaker phone. Not sure what the problem is.
1Coopgt
641
61
28
Are you using a case on your phone ? If so what kind ? If you aren't using a case are you making sure the mic on the phone is near or pointed at you mouth ?
leehardballer12
101
....or a poorly placed screen protector that is partially blocking the mics at the bottom of the screen.
carla3610
4
I do have a cover on the phone but it does not cover the microphone part. That is located at the very bottom of the screen. I also have a screen protector on but it does not cover it either. I can turn my phone off and sometimes that will correct it but not always.
1Coopgt
641
61
28
Interesting you said that restarting the phone sometimes correct your issue . You may want to try doing a factory data reset . Sorry I got nothing else .
Ch4dders
102
Agreed, this sounds more like an issue with the phone itself, not a case/screen protector. I'd even consider called VW tech support. Maybe they can get you a replacement device.
Posted from 64GB BN Droid Turbo
carla3610
4
Update....I went online with Motorola for my complaint. He had me clear cache in the boot menu. Problem resolved so far.
D._Manley
91
That works wonders at times for other little glitches...add one more to the list. Thanks for posting. FWIW, my hearing is far from normal & my Turbo is louder than I actually require - I can hear OK in normal situations with the phone not touching my ear at all.
