I have the droid turbo 32g. If I am listening to something on headphones and someone calls, the in call volume will be wake-the-dead loud. I can try to adjust the volume either before answering the call or after answering, but it makes no difference. It is loud enough that is uncomfortable to keep the speaker against my ear. I'd say this happens about 75% of the time. I can't figure out why it occasionally works correctly. Does anyone else have this issue? Is there a fix?
Fyi- I listen on headphones set to the lowest volume setting, so it's not a loud volume setting that's getting stuck when I answer. It's increasing to what I imagine is the max volume and won't decrease. I also take my headphones out to answer the call, in case that's a known issue.
