This is something I've wondered about for a while, but it hasn't seemed to cause obvious issues, so I haven't investigated further. If it is an issue, maybe correcting it can give me a performance bump somehow, though.
I have the setting to show WiFi notifications in the notifications panel set to on. This gives me the "Wifi Connected to (network)" notification in the notifications shade when it first connects.
The possible issue is that I see this notification reappear periodcially after I've cleared it. Even if my location/network hasn't changed. I assume this means the Turbo has disconnected and reconnected to the WiFi network, but there isn't a reason it should have (eliminating situations where I moved enough or where a public connection sucks).
My home network does this quite a bit, but otherwise we don't have issuess with it disconnecting on other devices. It also doesn't seem I have WiFi issues when using the Turbo at home.
I do have WiFi Optimization active. Is it possible there is a disconnection happening as part of that feature? I'm guessing not, but this is the first thing other than an actual problem I could think of. Also, I have the "Keep WiFi on during sleep" setting set to Always.
Any thoughts? If the WiFi keeps shutting on and off, I figurte that's not for the best when I'm in my home network. So, curious if others see this or know what the issue might be.
