Help! Lollipop: Unfortunately, System UI has stopped
HELP! I'm in trouble Turbo users and really could use some help here.
So I updated to Lollipop about an hour ago and was poking around trying to find any new options in 5.1. I went into Developer Options and turned on/off settings one by one to see what, if anything they did. I tried to tap on an option to turn it on (unfortunately I do not know what the option was because of what happened next. All I know is that the option was the one immediately under the margins option -- or whatever the option is called that puts the red and blue brackets around all the words, etc on the screen(I think it was called margins but everything happened so fast I don't recall exactly)) and the screen went blank then came back with the default background (which I do not use) then went blank and came back with this message: "Unfortunately, System UI has stopped" [ok]
I tried restarting my phone. Same thing. I get past the Droid welcome screen and then "Unfortunately, System UI has stopped" [ok]. Pressing [ok] only makes the box go away for a second and then reappear. My phone will not boot past that message box. I can turn off the phone and get to the Fastboot screen (power + vol down).
Is there anything I can do short of a complete factory wipe? I really don't want to do that unless its necessary!
