A
AC Question
Sometimes I'll grab my phone to find that it isn't waking up. The screen is black and it won't turn back on. I know the phone itself is on because if I turn up or down the volume it makes the beeping noise, but the screen won't turn on.
Sometimes if I just push the power button over and over enough, it'll eventually just wake up and work fine. Other times I just have to turn it off and on again.
The weird thing though, is that whether or not I just turn it off and on again or hard reset it, it never seems to actually turn off. It acts as though it was off all along and goes straight to the Motorola logo as if it were turning on normally. And sometimes it will go through the whole Android booting animation with sound and after a few moments, instead of loading up normally, it will just turn off again.
Other times, when it's being unresponsive I won't even be able to hear the volume beeping. It will just have turned off without any reason. It says the battery is fine and it's charged up more than enough. And to make matters worse, almost every time this happens, in order for it to start functioning normally again, it first goes through an extremely long series of "optimizing apps" (77 or so of them.)
Help?
Help?
