So i've been using launcher pro for about a week now and all of a sudden im experiencing serious lag when flicking through homescreens. I haven't changed a thing widget or app or setting wise. What's going on?
I don't have a task manager installed. Im going to try switching back and forth now...
My husband says it is laggy (is that a word?) on his Incredible and he is thinking of dropping it. I haven't had any issue on my X so far.
Id put a MILLION dollars on a app conflict. Anything get installed around the time this started happening???
My LP has been running fine. Don't know what your problem could be. Task Killers aren't very good things for Android, as you'll read all over.
I believe that others have reported that the Incredible allows you to disable the sense interface, did he disable that before running Launcher Pro Home screen because maybe there is a conflict with both running since they are both powerful interface.
please not a task killer. any way my lpp has been running fine no problems and no task killer involved. android does a good job keeping mine fresh.Try installing a task manager and use that, you might just be getting bogged down by apps
Advanced task Killer is the popular one
