~~~The unit won't stay off during charging....
~~~it's a proximity sensor that turns the screen black (during call, etc.)
~~~When typing on the virtual keyboard you can swipe down to make the keyboard go away.
~~~from your home screen, press menu, then settings, then go to 'About phone'
--> Status: i like that it shows you how much battery life you have left in percentage
--> Battery use: Cool way to keep track of what is killing your battery
~~~Settings >> Applications >> Development >> Stay Awake (keeps screen on while charging)
~~~I like that the search/home buttons have separate "long press" functions.
long press on Home gives you a list of running (or recently running) apps, and long press on Search brings up your voice search.
~~~The Droid doesn't have a speed dial list. Instead it has a favorites list. To add a contact to the favorites list:
Go to contacts and touch the star in the upper right hand corner. When it is lit up, the contact is now part of your favorites list.
~~~If you want to add custom notification ringtones for your emails, sms/mms, ect., plug your Droid into your computer, access the SD card, create a new folder on the card called "notifications", and drop the ringtones you want to use into the folder. When the phone is unplugged from the computer, the Droid will be able to use the new tones.
~~~~To watch youtube videos in High Quality, start the video, press settings, and click on "watch in high quality
~~~~~you can also add the contact on your home screen by touching on the home screen and hold then a menu will pop up click shortcuts then pick a contact from there works great
~~~~Maybe a known step but took me a while to figure it out. While on the web, if you wanna save a picture (for wallpaper purposes or whatever). You have to hold your finger over the picture and the "save picture" message will come up.
~~~~On the virtual keyboards if you long press any button with "..." next to the letter or number it will bring up another list of options.
~~~~save album art images for music as folder.jpg to keep them from showing up in your gallery. also store mp3 ringtones in: /sdcard/media/ringtones to keep them from showing up in your music database.
~~~~Keyboard shortcuts:
go to Settings > Applications > Quick Launch to view and set keyboard shortcuts.
~~~~just discovered you can use the barcode app to share contacts, bookmarks, etc...
open Barcode, press menu button, select share
