I got my phone out of my pocket tonight to make a call and it was off. I tried ti turn it back on and it will not come back on. Any suggestions on what to do???/
sorry to state the obvious, but is the battery dead?
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Will it let you do a battery pull and initiate a hard-reset?
