I've rooted, and tried many roms with my nexus 4 and I know i've done something to cause the network speed to be averaging about .04 mbps. I've spent the last 2 weeks trying to fix it by doing a couple things and can't find the answer anywhere. I'm using Straight Talk Tmobile in SLC, UT. I use to get 8 mbps easy. This is what i've done to try and fix it:
Verified APN settings are correct
Have flashed different radios
Used the Nexus root toolkit to unroot, and return to stock
I did the whole #*#*4636*#*# and clicked on "run ping test" and it says: Ping IpAddr: Fail: IP addr not reachable
Any advice on what to do?
