I don't think the TGSPs adhere completely to the surface of the phone like the soft plastic ones.
The one plus protector does. All other ones I have tried, do not. And I've gotten dust under those.
So the TGSP from OP adheres completely to the screen? Good to know. Thanks. Does it work well with cases like the Spigen Rugged Armor?
I have the Spigen Rugged Armor and so far it looks fine. I have had it for barely a week though so can't tell you about longevity.
Hi there,
are you refering to the Curved Temp glass from OnePlus? or the regular Temp Glass from OnePlus?
Thanks
