- Feb 6, 2017
- 98,869
- 15,513
- 113
Yeah disables 3rd party apps , is YouTube available?
Earphone mode was in settings of sound , this on my 1+7t McLaren on Andriod 11YouTube is available, however, the internet is not and it's not readily apparent how to get anything working with safe mode applied.
As for the menus, the Settings -> Sounds looks the same, but I am not seeing an Earphone mode menu when I search for "Earphone Mode" in settings.
The Earphone mode menu was removed in A12. They added some options in the Dolby Atmos menu and the Absolute Volume can be switched on/off in the Developer Options (I'd recommend you to leave it turned on).Doh @mustang7757 that must be the problem here. I am running on Android 12 as stated in the first post. Have you been able to verify this on a 1+ device running Droid 12, by chance? This seems like a bad bad bug with the latest OS.
Yup, it seems a bug affecting different models after the A12 update. I'll keep searching for a fix, but until now I've only found what I posted before (fixed on its own or Developer Options trick). I'll keep you posted.OK that makes more sense. I have tried toggling the absolute volume on and off and it still does not appear to work as advertised. It seems quite broken, unfortunately.
No it hasn't updated to Andriod 12 yetDoh @mustang7757 that must be the problem here. I am running on Android 12 as stated in the first post. Have you been able to verify this on a 1+ device running Droid 12, by chance? This seems like a bad bad bug with the latest OS.
Try thisAlso, if anyone can assist with how to Report a Bug to the OnePlus Community that would be appreciated. I only see New "Moment" and "Article" as options.
To create a thread or give feedback in OP Community you need to login first. This can be done from the phone general settings. I haven't used the app for a couple of weeks but I remember that the feedback option (in the '+' floating button bottom right) was broken, I'm not sure if it's fixed now.Thank you very much for that link @mustang7757. Did you try the provided link, by chance? When visiting https://forums.oneplus.net/feedback/ it goes to https://community.oneplus.com/home for me. I still do not see where I go to submit bugs. Pardon the confusion here if there is something obvious.
You can login from your computer as well.Ah that might be the problem, I am visiting from my PC.I will try from my phone. Thank you very much for the assistance!
App only these options when tapping the +View attachment 346743
