[ROM][WIP][ICS] The Godzilla Rom - Tweaked And Themed CM9!!!
Status
Not open for further replies.
torch2424
116
111
Hey, Torch Here With his Second Project :D
What Rom Is This:
A Tweaked And Themed ICS Rom, Based upon BobzHome CM9 Rom
Features:
Translucent Status bar!!! :DDD
Build.prop tweaks!!!
-Stability
-Performance
-Battery Life
-Better App Compatibilty
-3g Speed(Feels A little Faster)
-Network Speed(Feels ALOT Faster)
-In Call Tweaks
-Youtube Tweaks
Init.d Tweaks!!!
-Stability
-Performance
-Battery Life
-better SD card reading speed
-better memory management :D
Awesome Boot Animation!!!
Trebuchet Launcher!!!
sysctl.conf Tweaks!!!
Supercharged(Makes scrolling VERYYY smooth, and Gaming is AMAZING!!!)
Adrenaline Engine!!!(Makes Phone Smoother!!!)
Status:
GREAT Performance(Overclocking is almost required for a good rom in BobzHome,But runs alright in default clocking on mine :D) And Great battery life!!! Smoother than a Baby's Bottom!!!
How to be battery smart - Improving battery life ? inferiorhumanorgans/android_device_lge_thunderc_common Wiki ? GitHub
Not Working:
USB Tethering
Bluetooth Calling
Fixes:
-Taken from Bobzhome's thread
Camcorder with Videocam illusion from the market
Video playback, you need to install either:
MX Player plus the ARMv6 VFP Codec from the market
or
Mobo player plus there ARMv6 VFP Codec from the market
-Suggested by cmerlyn
"I noticed the panorama camera is still listed as not working. There is at least one free app that does work for this: 360. There are probably others, but that is a starting point."
- Message By dosangst
"I was able to fix voice search by using super manager and removing the a p k from the system folder and then reinstalling it from the market..."
Screenshots:
Current Release:
Build 3.1 is not signed!!! turn of signature verification D:
ALSO, IF ON INITIAL BOOT SCREEN IS WEIRD, JUST REBOOT AND THE PROBLEM SHOULD BE FIXED :)
AND IF YOU GET GOOGLE PLAY STORE SERVER ERROR JUST REMOVE YOUR GOOGLE ACCOUNT AND RE ADD IT! :D
Build 3.1: http://*******/ANS6G
Replace stars with "*******", if they are there :)
^^^SUPPORT THE DEV LINK!!!^^^
Alternate link: http://www.mediafire.com/?as4uutpuka8l5a7
Gapps:
Bobz Gapps: gapps-ics-20120429-BobZ.zip
The Kraven's Gapps: Goo.im Downloads - Downloading gapps-ics-20120429-small.zip
Honestly, I suggest the Bobz gapps, they seem to work better for me :)
How To Submit Bugs:
Post In this thread, And I'll Try To fix it!!! :D <3
How To Install:
1. Boot into recovery
2. BACKUP!!!
3. Wipe Cache & Dalvik-cache
4. Format system, data, and cache
5. Install zip from sd card (Choose the rom)
6. Wait...
7. Install zip from sd card (Choose Google Apps)
8. Reboot(Will take a while)
Suggetions:
Alternative launcher(Apex) - https://forums.androidcentral.com/e...?id=com.anddoes.launcher&hl=en&token=DfdToCYO
Flash Aphetamines for better, faster rom - http://forums.androidcentral.com/op...d-amphetamines-inject-your-optimus-today.html
Use one of AnthonyCR's Themes, They're hella cool!!! But removes translucency :'( - http://forums.androidcentral.com/op...-slate-afterburner-volcano-etc-hdpi-mdpi.html
Also, I suggest leaving surface Dithering off, it helps performance alot if it is off, but if you cannot stand occasional graphical bugs, than turn it on :3
Special Thanks:
BobzHome - For allowing me to use his rom as a BASE
Skunny - Mentored me through my computers my whole life
Cyanogenmod Team - You guys make android better than it should be every moment all the time :D
TDM - For inspiring me into ICS and allowing to use his MMS apk to make my own :D
knzo -Your Tweaking list :D
el_liberator - Your translucent status bar guide :D
matt5eo - Your modded trebuchet apk, I couldnt ask for his permission as he was banned from xda :/ please like his thread([MOD][CM9] Trebuchet MOD [Launcher] - xda-developers)
zepplinrox - his supercharger is the greatest thing for android, ever (http://forum.xda-developers.com/showthread.php?t=991276)
MДЯCЦSДИT - your sysctl.conf tweaks :)
PureMotive - your sysctl.conf tweaks :D
bududroid - Your Beats Audio (http://forum.xda-developers.com/showthread.php?t=1561484)
sammyz - for his canibal recovery fix :3
imbawind - The adrenaline engine (http://forum.xda-developers.com/showthread.php?t=1604321)
rockodev and eternity project team - permission to use your beats audio :D
Please Thanks these people who have helped and contributed to this rom!!! :)
f you need ANY help at all please post and I'll respond ASAP!!!
Please Press "Thanks" and "Like" if you appreciate this! ;D
ALSO NOT RESPONSIBLE IF YOU BRICK OR DAMAGE YOUR PHONE!!! But I doubt you will, since I test my products :3
Currently Working On:
Finding someone to take over this rom...
Changelog:
Build 1.0 - great performance!!! but medeokre battry life :/
Build 2.0- GREAT PERFORMANCE!!!(SUPERCHARGED), added more tweaks(sysctl.conf and init.d), better in call volume,Removed debug tweaks in build.prop(offered slight performance at HUGE bettery drain :p), VERYYY good battery life, replaced CM9 music with Apollo(Bobz Default), and last but not least, added Beats audio for better audio :D
Build 3.0 - removed Beats Audio (makes weird white noise whenever sound is supposed to be played :0), synced with Bobzhome(CM9 RC1), added adrenaline engine!!! and the greatest bootanimation ever (not fullscreen but its WAYYYY better than the last one ;D)
Build 3.1 - synced with Bob, and added translucent system apps!!!! :D Screen issue might be fixed :3
Ryuk6666
489
88
You said stability, performance, and battery life twice xD lol
Edit: gonna flash in a few :) thanks man.
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
topdawg661
333
70
Screen shots? :eek:
Edit: nevermind I passed them lol looks awesome ill flash in a bit!
reaper420
215
21
i couldnt get it to install, when i tried it said it was missing assets or something. im using cannibal recovery if that makes a difference. is anyone else having this problem?
torch2424
116
111
Yes unfortunately I believe you cannot flash this with cannibal, as Bobz rom wouldnt flash with cannibal either, thank you for reminding me, I shall update the OP :/
But I will fix in the next build :D
Reactions: Ryuk6666
sammyz
825
190
Maybe its just the fact that you flashed over it that it fixed it?
reaper420
215
21
well i tried reflashing and it said mms was missing thats why it wouldnt install, i checked the zip and it was missing so i redownloaded it and and the mms is there so i suppose it was a bad download im gonna reflash later and see
Ryuk6666
489
88
Cant flash :'( super sad face.... Im using cannibal Dx oh wait. Ill just flash my copy of th7 MWAHAHAHA!!!!! >:3
sammyz
825
190
Try this:
In the rom go to /meta-inf/com/google/android/updater-script open it with notepad and delete everything before the first semi-colon and also the first semicolon. After that save and repackage into rom.....if using winrar/7zip a prompt will ask if you want to update the zip, press yes, if using windows explorer to open the zip, go get 7zip or winrar....
Reactions: Badboytoast
Status
