bradhoschar
Installed this ROM on Friday. Had a lil problem syncing to Goog, but after i wiped the cache, it worked fine. I have CPU master free running stable at 787...haven't noticed ANY bugs with it....Very good work guys, keep it up:-$
what is the camera fix for the 6/01 build?i know its probably in this forum somewhere but i really dont want to dig through hundreds of pages trying to find it..:-\
thanks,but i know what its for what i meant tho is how do i get it,is it something i have to install on my phone or what?The camera fix is for fixing the auto focus I believe.
I believe its a flashable zip that you can flash from the recovery menu, the one where you flashed the rom. The download should be maybe 10 pages back or so.thanks,but i know what its for what i meant tho is how do i get it,is it something i have to install on my phone or what?
appreciate it.I believe its a flashable zip that you can flash from the recovery menu, the one where you flashed the rom. The download should be maybe 10 pages back or so.
search is your friend, or should be!
haha i never even noticed thread toolsIf you use the search this thread tool at the top of the page and type in camera fix, you can find a link to the original post about it over at xda, search is your friend, or should be!
when i try to flash the camera fix this is what it doesYou should wipe cache and dalvik cache since the lib files are different. Then just flash it.
install from sd card...
finding update package...
opening update package...
E:wrong digest for META-INF/MANI
FEST.MF in META-INF/CERT.SF
E:Verification failed
installation aborted.
turn off verification from within your recovery and it'll let you flash it.
Sad - this thread seems to be dying. I guess the long delay since a new release has kind of killed interest in this rom? Or are the other new gingerbread roms stealing the attention?
