ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
Sometimes the screen takes 2 or 3 seconds to load but it don't happen to me often. I don't use the keyboard sideways a lot.
The only real problem I've had is the android keyboard actually force closing, but comes right back, its not a big problem just a lil annoying sometimes.
Sent from my Optimus V running CM7 @ 825mghz
What recovery are you using? Did you also flash the gapps.zip?
I Gave up on Aosp and am now running Bumblebee 2.4. It was able to install flawlessly.
I tried all options listed on multiple forums and was not able to get Aosp to boot past the Android scroll.
My best guess is that there is a compatibility issue with CWM that I am just not quick enough to catch.
On a side note I keep getting switch to "Edify scripting" errors when installing .zip files. I was able to get Bumblebee to load after re flashing CWMR.
Just out of curiosity, what's that about?
Thanks,
Jake. :)
Don't use cw, use xionia recovery
It's my understanding ( maybe false ) that I can not use Xionia because I am not able to run SDK on my Win7x64 machine ( my only option ). I have no interest in setting up a virtual machine to run XP.
Is that correct?
Thanks
Is that correct?
Thanks
I was using XIONIA and I run WIN7 64
gapps-gb-20110325-signed.zip
MD5: 4cbe712c0bde778fb7f2d32d32b57dd8
aospCMod-OV-20110531-signed.zip available on Rom Manager under "Download Rom"
aospCWMod-OV-20110531.img
MD5: e75e92d259c675b9dfd5113bd1cd0939
WIKI
Follow AOSPBOT on Twitter for latest OV updates
Live Support
[GPL] Kernel Source
Original XDA Thread
aospCMod from Optimus V to Optimus S .zips
HOWTO Logcat (DEBUG)
ROM/Kernel DEV: aosp (Donate)
I'm just sharing the rom link with android central.
aospcmod-ov-20110427 is what i currently have on my phone but witch one is better the one i have now or gapps-gb-20110325-signed.zip any help would be much appreciated.
Why not run the 6/01 build? Its the newest and most updated. The only bugs are bt/headset and camera, but there's a camera fix.
im still sorta newbish and i dont know how or where to look for updates at,and if you you would be so nice to send me the link or tell me where to find the 6/01 build it would be much appreciated :)
Go back three or four pages, I posted the official link from the romshare deployfu website. Go back a few more pages, and someone else posted it, go back a few more pages, and someone else posted it.
I know it's hard to find things right now, your best bet for up to date info is to start at the end of the thread and work your way backwards. ;)
Reactions: mtndew948
do you need rom manager premium to get this? i don't see it in free rom manager...
you have to use rom manager to install clockworkmod 3.2.0.1
then use manual flash override to tell rom manager your phone is a "LG Optimus One P500"
now when you go to download rom, it will show under AOSP.
its just in the wrong place. youll need the GAPPS too.
the rom is labeled for VM670 so its clearly the optimus V version of aospcm7
anyways thats how you get it on rom manager
ugh. none of my buttons work properly in 3.2.0.1 recovery. My menu button makes the screen disappear, home does the same, back resets the screen and search does nothing.
Try the side buttons: Voice / Camera
Volume rocker moves up and down, camera selects, back goes back.
Status
ahmedhadeethy
