After using this ROM for a few days, the only complaints i have are that the stock headset button doesnt pause the music player, didnt know how much i used this until it didnt work anymore.
also for the life of me i can NOT disable the cyanogen lock screen....
i usually have my phone set up with JUST a pin number lock, that i toggle with a widget, so when im home i can turn off my screen and not have to unlock it everytime. and when im else where i can turn on the lock.
now, when the lock is off, the phone turns on normally, but when the lock is on, both my PIN lock AND the cyanogen lock come up. best i could do was disable the slider and use the menu button to skip that screen and go straight to entering my pin.
but i should not be forced to use a lock screen. i should be able to choose.
any one know how to truly disable it?
