No my Wifi stays on when screen locks unless I was to add it in Tasker same as my 3G shut off. I was just commenting it uses alot more battery then 3G especially on GB, alot more then Froyo.
This is a built in feature of android. Goto Wi-fi Settings...Menu...advanced...wifi sleep policyI use the program "WIFI Keep Alive" from the market. It lets you choose what the wifi does, I.e. stay on with screen off, go off with screen off, or stay on only on power plug. It works great and saves me a ton of battery. Last night I used it and before I go to bed I would lose like 20%. I only lost 5% with this enabled.
what happen to other color in theme changer? I like the blue one in ZCM7
I need a ROM God to get full MMS working on this! PLEASE!!!
my mms works...just have friends that send a lot of 9999999999s .This has been addressed so many times.
Posting you need a rom god to get it working might make you feel better, but in reality its just filling the thread with more drivel.
First off the way Virgin sends mms is almost at pentagon encryption levels. Some of the best devs have took a crack at it and walked away scratching their heads. Its a very proprietary method and nobody wants to spend the amount of time required.
Second if you need mms soooooooooooo bad the best bet is to go back to a stock rom. Otherwise tell people to email you the pictures and funny messages at your email. It is pretty much the only way right now.
i have a question. so far i loving both roms ZCM7 and AOSP CM7 too but i prefer to have stable rom so do you know where to get Gingerbread blue keyboard?
Eoillie is right. VM messed with vanilla android code and baked in MMS settings to decrypt in framework. Would take a full time code banger to get it right. Unfortunately...while Optimus has great devs....none on the GB mms VM fix payroll. Find more info here: Mind crunching MMS stuff
I prefer no mms....saves embarrassment from the morning after the bar
Check your running apps.Hey forgot ask, what would be the best way to find out what causes my phone to slow down. Let me explain. When I first start the phone it runs great, super fast. After a few hours and some use it seems to slow down significantly, 4-5 sec rotation lag and my camera takes a while to start, etc. What would be the best way to find out what process is causing this. In Windows I could shut down processes. What do I do here? Should I go into Manage Applications and shut off apps in the "ALL" tab one by one? I havent tried this yet but does anyone have any suggestions on this? Thx
Normally there is one that is thieving processor time.
