ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
I know that most things do work with aospCMod but what doesn't work besides mms? I want to make the switch but I need to be sure that I won't lose any main features.
According to the devs at Swype, you need to keep Swype on the phone's internal memory, and not on the sdcard. As an input method, it must always be available to the OS, otherwise the OS will look for another input method. This will keep Swype as your default until reboot.
At reboot, the default Android keyboard is enabled, and this is due to Swype being beta software at this time.
Note-this only applies to the Swype Beta, not the pre-installed Swype
This is something i've been wondering about for a long time. What's the real difference between pre-installed swype and the beta swype? Anyone?
update in OP. leaner meaner faster stronger.
Incoming MMS has been pinned down to exact problem. aosp and claudia c are hard at work!
Reactions: ashton4life
on the last build my headset still did not work. I could hear on a call but no one can hear me.
That sound encouraging. I figured we never see Incoming MMS on 2.3 until a official rom was released. Good news!
how did you install it?
i wiped everything and all the caches and installed it fresh with the new gapps.zip thats also up there. i have no problems, installed everything from the market.
this rom feels a bit smoother but i bet nothing major has been changed or it would have been noted more right?
I install it like I always do. Wipe factory data, wipe cache partition, and the dalvik cache. I did flash the current gapps, twice because it gave me that error, but it still didn't work after that.
anyone else have an issue talking using this rom and the headset that comes with the optimus v?
Just in with this rom, headset issues remain, though wifi hotspot now works with Quick Settings
For what it's worth, I would consider the battery life issue fixed as I am getting Rodimus-like battery life out of this ROM now
I'm having issues with my home button and search button not working at all. The other 2 buttons seem to work fine.
No matter what theme I use, my status bar icons won't change. They stay grey. Only one that changes is the battery. I even did a fresh wipe install. Like EVERYTHING changes like normal except the icons in status bar minus battery (it changes) Is this just me?
[ Sent from an LG Optimus V ]
Mine changed with themes useing cyanx. The wifi and 3g are gay till they fully connect then they change color.
Mine hasn't changed since I flashed a custom UOT kitchen theme. Now any cm7 theme I install wont change. Grrr
Status
criteriascenario
