EarthnFire78
YAY!!! ME :)
Run repo sync -j1
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Tried and still get the same error.
Run repo sync -j1
I'm also trying to figure out how to get my build tree synced back in time (say, to N days ago). But I'm enough of a git noob that I can't figure it out. I have a script that parses manifest.xml and runs through all the directories but I don't know the command to sync the git tree.
If you look in manifest.xml for CM9, for example, you will see the default revision is "refs/heads/ics". So let's take the first project entry, which is "build". It uses the default so...
Code:$ cd build $ git checkout refs/heads/ics error: pathspec 'refs/heads/ics' did not match any file(s) known to git. $ git show-ref | grep ics 569e20838ebaf6e7ce1fc517602a9976e67f6e1c refs/remotes/github/ics 569e20838ebaf6e7ce1fc517602a9976e67f6e1c refs/remotes/m/ics
So .. uhh .. where is "refs/heads/ics" and how do I sync to it?
I don't use the method often, but you can use git revert HEAD^^^ with the number of ^ equal to the number of commits you want to go back minus 1 (revert HEAD goes back one).
Git Book - Undoing in Git - Reset, Checkout and Revert
git checkout ...@{time}
Thanks but I want a time based checkout. I know the syntax:
Code:git checkout ...@{time}
My issue is finding the branch/tag or whatever. :/
Type lspci -v in terminal and post the output for your wireless lan controller. We need to know the chipset it's using and we might find a better driver..Think I know why I'm having problems; the wireless card disconnects after a while. Is there a better Linux driver for the Realtek Wireless? I'm running 64bit Linux-Mint if that matters.
Only does this on Linux, in Windows the card works great.
I'd like to try this out.
Sent from my Droid using Tapatalk 2 Beta-4
Start off with the OP this thread. It walks you through step-by-step.
Can I build from source for the original moto droid?
[SIZE="2"]/bin/bash: prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-gcc: No such file or directory[/SIZE]
[SIZE="2"]sudo apt-get install ia32-libs[/SIZE]
question.. i added magpie apps2sd-ext into iho, everything seems fine, except i can't get the ext partition to mount... isnt that what 05mountsd does? or am i missing something?
