pergerson6
A lot of work still to be done: Click to view quoted image
more pic's here: http://s1120.photobucket.com/albums/l494/BobZhome/ics/
Please port this to the OS!
more pic's here: ics pictures by BobZhome - Photobucket
Wow!
I commend you on your progress, you have skill. Also my latest 7.2 build has had some touch screen accuracy problems. Off by at least a centimeter sometimes othertimes its perfect.
Is gpu acceleration enabled or disabled?
Well I used a touch screen calibration app and its saying its dead on. But It feels like its randomly hitting a little lower. Like I have my ram widget where it updates whenever I touch it. I have it on the bottom right corner and my dock has the web shortcut right below and if I touch the bottom corner of the widget it instead launches my browser. But sense I used that touchscreen app im more inclined to believe its user error lol.
Widget touch poinnts are sometimes off, especially if you resize them, its a launcher issue, not rom or kernel issue
Does this mean, you have a working build. So is wifi, 3g and data is working. I saw pics of it thats awesome.
I usually leave a backup of working code on an external ext 4 formatted hdd so that it can compile or be moved without losing it's permissions. last night i started applying changes to that and messed it up big time. Is there a way to use repo to fix that without having to wait four hours?
mv .repo ../
[COLOR="Red"]rm -rf ./*[/COLOR]
mv ../.repo ./
My current TARGET_ARCH_VARIANT := armv6k-vfp
I'm going to cherry-pick this: Gerrit Code Review and try it since it is armv6-vfp, which is what we have on the OV.
If tonight's build works out good, I'm going to try this dalvik support: Gerrit Code Review on tomorrow night's build.
beware of the rm -rf my son, it can be used for good or evil but it has great power over both.
git clone git://github.com/BobZhome/vendor_lge_thunderc.git
git clone git://github.com/BobZhome/android_device_lge_thunderc.git
git clone git://github.com/BobZhome/android_build.git
git clone git://github.com/BobZhome/android_dalvik.git
git clone git://github.com/BobZhome/android.git
git clone git://github.com/BobZhome/android_frameworks_base.git
git clone git://github.com/BobZhome/vendor_lge_gelato.git
