[Help] system reset when reboot, stuck on LG splash screen
Dec 12, 2011
5
I formated the system, boot and
I flashed xionia_cwma_12518.4 to the lg optimus v.
now there is not rom in the system, and every time I reboot, the phone will go through
android system recovery
do not pull out the bettery
formatting data:...
formatting cache:...
factory reset...
rebooting...
and stuck on the lg splash screen.
when the phone is connected to usb, the computer is trying to install the driver, but because it automatically go throught the process described above, it will disconnect before the driver can be installed.
so adb cannot see the device.
what should I do? thanks.
arnold1997
693
117
formatting data:...
factory reset...
rebooting...
I had this same problem
There is a thread called
[FIX] ADB method to break factory reset bootloop by wiping /mtd8
By bigsupersquid
I fixed mine like this
Sorry cant give u a link im on the mobile site of the forum
**EDIT** sorry didnt read the part that adb did not reconize it
5
Leave the phone on then connect to computer then check of adb sees it wether or not if the drivers installed
thank you. Tried this.
in command line. it shows:
Erasing 128 Kibyte @160000 -- 91% complete
/sbin/sh: adb: not found
Now the recovery is gone, only the lg splash screen left
I guess the phone is now without a recovery nor any rom.
clodfelterac
Samurai Dev
Jan 3, 2012
729
206
try reinstalling the drivers on your pc... perhaps that will help... im pretty sure youre gonna have to push new recovery and rom via adb to save your v... but... it CAN be saved!...
edit: go to leslies2012ov reference guide... post#10... hope this helps... :)
arnold1997
693
117
Try this
Take out the battery
Press the recovery combo (Home+Volume Down+Power)
Then while holding that insert battery again
And maybe boot to recovery
Dec 12, 2011
5
Try this
It worked!!
In the Xionia CWMA v1.2518.4 now.
should I replace the recovery to something else using adb now?
(I installed xionia cwma in order to break the boot loop ealier)
or what should I do next?
arnold1997
693
117
Good!
Now do this:
Wipe data/factory reset
Then wipe cache
Then go to advanced and wipe dalvic cache
Then flash ROM
Then flash gapps(if needed)
Then reboot
Post the results
