[ROM][WIP]CM9.1.0-BobZ
leeroy4000
6
Re: [ROM][WIP]CM9.0 RC1-BobZ
I'm on quattrimus but I had a similar issue to this with Facebook. Try forcing gpu rendering under developer options... Might not work but it did for me.
I'm having this problem as well. Was having it with browser, facebook, pulse, email. It was not consistant though. I did a fresh wipe and reload flashing the ROM, Bobz gapps and amphetamines all at once. Everything but Facebook is working for now. This is the most stable it has been for me so far. I also did the GPU force and no overclock. I hope it sticks.
inceyet
393
121
@bobz just flashed your 7/3 update great work I oc @ 600/480 interactivex very responsive, music is running great , apps running the way their supposed to
Also is there anyone running a higher oc if so what is it.
orlin2
11
I don't know how helpful this will be, but I've only had one consistent fix (for myself) on ICS ROMs, dealing with Facebook. I have a TB backup of Facebook from when I was running IHO-BACKside. After flashing an ICS ROM and installing Facebook via the Play Store, I restore the Facebook app (app only) from TB and it works, for some reason. Again, this only works for me, but it may help others.
nixie21
135
5
I am running at 600/768 interactivex with no issue...tried 787 high and got reboots.
Reactions: inceyet
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Yeah. The best version right now is one that works, but if a call comes in the call slider to answer / ignore won't show up at all.
inceyet
393
121
Wierd thing happened had to reboot then after that it went into this rr frenzy just wouldnt stay on :( had to restore a backup i was oc at 768/480 interactive for the last couple days any ideas
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
Thanks Bob. Flashing ASAP.
@hurdurp its about the same stability and my only problem with it prior to this build was USB storage not working and now its fixed. I had zero reboots on bobs rom whereas I've had reboots on tdms and bobs is definitely smoother. Word on the street is that bobs kernel is magical.
sellers86
1,837
617
Yes, it is. Haha.
Sent from my VM670 using Tapatalk
HurrrDurrrDURP
356
111
Re: [ROM][WIP]CM9.0 RC2-BobZ
Always loved bob's kernels. :3
anthonycr
Jul 11, 2011
2,104
571
Flashed the new build a little bit ago and I have to say "wow" either your kernel really is magic or you managed to implement the project butter stuff into the rom because there is absolutely no lag. Couple problems though: USB storage isn't working still (I might have misunderstood the change log) and for some reason my brightness is stuck jacked up to full and won't go down. Other than that this thing destroys everything else. :cool:
Reactions: BobZhome
sellers86
1,837
617
for the brightness thing, see if auto brightness is enabled.
EDIT: he updated his kernel, that could be why its even smoother than normal
anthonycr
Jul 11, 2011
2,104
571
Auto brightness isn't enabled. I downloaded a root access brightness app and it was able to dim it but for some reason the settings does nothing. I didn't do a dirty flash so its not like I messed something up...
jaredw444
173
13
Same here brightness stuck on high, and I can't change it so I can control brightness by notification bar( which is handy)
plays by prison rules
BobZhome
296
627
Confirmed, something is wrong with brightness...Thanks!
USB storage is working with my Ubuntu server, which is what I use to build and tested on, but for some reason I just checked on my Windows 7 laptop and it didn't work :confused:
Sorry, I should have test on multiple computers :-[
sammyz
825
190
It may actually be a driver problem, even if you have have the newest driver installed, it's sometimes the older drivers that actually work....my BACKside port for the Optimus M has this issue, new drivers don't work, old drivers do.
