anthonycr
Themer. You've seen them
Im tryin to partition my sd card but i cant baccup my stuff... wat could i do?
You can mount USB storage in recovery
Where is that menu?
I have CM7 IHO build, and quite frankly dont know how to switch to this.. awkward.
Is it worth it if my CM7 bothers me with the hiccups it has sometimes? Battery Life is huge for me.
Thanks if anyone can help me!
Well, it was super smooth, but I reverted to aokp because your rom has the Pandora skip bug. If I remember right, that is linked to audio files
I just tested Pandora out of curiosity and didn't have any issues. Could you expand on how to repeat the bug
What keyboards are you guys running.
What keyboards are you guys running? I've tried ICS Keyboard, Stock, HTC IME (LOVELOVELOVE this one, but it crashes on this rom), AI Type (terrible), Swype Beta, Swiftkey 3, and the Jellybean Keyboard.
Is there a way to get HTC IME stable on our device or will I have to stick with something else? I do like Swiftkey 3, though, so I at least have a fallback.
