Help!!!!!!!!
devindj16
3
My little brother formatted his phone while it was rooted so im trying to get it out of the CWM loop.
I downloaded the stock rom and flash_image zip. I also have the xionia_cwma_12518.6.img.
I put it in the root of the sd card and tried to install xionia and the flash image through the recovery, but every time i do it, it begins to install, then it says installation aborted.
I don't know how to get around this.
Please I need some simple help.
Badboytoast
820
122
It should be something like this xionia_cwma_12518.6recovery.zip
Then you should be able to flash the xionia recovery. Zip within your old recovery!
Badboytoast
820
122
Have you tryed restoring your backup! Just make sure to do a complete wipe, hopefully someone with experience could help you more! Sorry , you could also try to re download the xionia recovery. Zip from a different thread and try to flash it again, it could be a bad download, if I were you this would be the first thing I do before jumping to adb which I have no ideal how to use :) good luck
