I recently bought a Dedicated Server from OVH, i installed Ubunutu 10.04 LTS Server, i'm trying to set it up so that I could build IHO/CM9 from scratch.
I've built on a pre-set up pc before successfully but I'm having trouble setting up the server to build.
I'm on Windows XP using Putty and I can download the Android SDK but that's where i'm stuck. The Android SDK won't install using a Non-Gui server
This post by Jerryscript #3 is what I'm following, http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/104423-building-your-own-rom.html#anb
I'd appreciate any help you guys could give me as I would love to give back to this great community by creating and refining CM7/9.
If it's important, my server has the following config
Processor Intel Core i3 2130 2x2(HT)x3.4+ GHz
Architecture 64 bits
RAM 16 GB DDR3
Hard disk 2x 1 TB - SATA2
RAM 16 GB DDR3
