I have a serious problem. My phone has been on for 1 hour and 54 minutes and its already at 85%. Its been draining like this since yesterday, but today is worse. My cell standby is at 60%, that's insane, but to add more, my Time Without Signal is at 88%! My TWS is raising every hour or so. But i dont get it, im using 3G and my signal is pretty good. I have Wifi off, Sync off, bluetooth off, pretty much everything off except Mobile Data. Yesterday i used Wifi with everything else off, and the drainage was pretty much the same.
My brightness is at 0% (its always like this).
Also my phone idle is at 25%, which seems a bit high.
So, id like some suggestions and help because i cant take a phone that lasts a couple of hours.
If you need any more info, just ask. Im using Aosocm7, the latest build.
My Cpu is set to 600/748. I had it underclocked yesterday and the drain was the same.
P.S. my battery is already at 81% now.
