ldscalgaryguy
Active member
I have a similar problem. I've found that on one size, the strap is just slightly too loose. On the next hole, it's slightly too tight. I'm wondering if anyone knows if it's possible to make a new hole halfway between these sizes. One thing I'm worried could happen is that the hole would be to close and then end up ripping to one large hole. Any help is greatly appreciated!
