Clearing "Missed Call" Notification From Gear
benhath
Active member
Jun 8, 2012
28
Does anyone know how to delete a "Missed Call" notification on the Gear with the new firmware? Whenever I press Notifications, it appears and there is no option to delete it that I can find. Reviewing the log does not do it either, nor does deleting the log on the phone. I have turned that feature off for now.
Thanks
Elly44
100
Yes I wondered this too. So now I guess we all know there's no way to do it for now. Hoping update will fix.
Elly44
From my Galaxy Note 3
marvinh
8
Thanks
I read in the online manual that the gear adds calls to the logs automatically and deletes the old entries automatically. Doesn't look like there is any way to delete manually. Marvin
cdf3
1,420
51
Can only be done on the phone itself. Then it disappears on Gear.
I've cleared all of my phone logs, disabled the Missed Call notifications in the Gear app, and I still can't get rid of the Missed Call notification within the Notifications of my Gear.
Sent from my SCH-I605 using Tapatalk
cdf3
1,420
51
I ended up having to reset my Gear in order to get rid of.
BillTheITGuy
Thanks
BillTheITGuy
Yes, I just discovered how to do this. A long press on the missed call entry on the galaxy gear will display a "remove" option thay you just press and it's removed.
priyapurushotham
Hi,
Hope you are doing well! To get rid of this issue please follow these steps :
* Go to Settings > Application Manager > All > Badge Provider and clear Data.
It should definitely fix your issue.
Regards,
Priya.
priyapurushotham
Hi,
Regards,
Priya.
benhath
Active member
Jun 8, 2012
28
Thanks for all the replies. I now have Tizen on the gear and it politely asks if you wish to delete the missed call log.
dumpsterrentals38
