You need the 45 watt charger accessory but don't waste your money.Mine never says super fast charging from the time I bought it. I'm using the charger that came with it. I'm just wondering why mine doesn't.?
Super fast charging is not possible with the supplied charger and it won't show unless it's triggered by the 45 watt charger.You look in device care if the option is toggle on ?View attachment 322825
Yeah super fast need the 45wSuper fast charging is not possible with the supplied charger and it won't show unless it's triggered by the 45 watt charger.
Both bricks say super fast charger and both will display Super fast on the S20 plus but the 45 watt is mostly faster on the front end of the charging cycle compared to the 25 watt charger especially on the S20 Ultra. In reality, Super fast is just a term and it doesn't tell you how fast it's actually charging.Then why does the brick say super fast charging and when my wife plugs her s20 plus into my charger her phone says super fast charging. I don't even have a toggle in settings to turn it on like hers does.
