New Samsung note 10 plus battery drain. Plz help! Plz
Toshiv Goyal
14
Hi, I have just bought a new Samsung note 10 plus device, 5 days back.
I'm getting a battery life of 13 -14 hours (i.e. charging at 8am to 100% and battery dropping to 15% by 9pm ) with around 4 hrs of SOT. This is with moderate to heavy usage. Bluetooth occasionally on, location occasionally on, AoD switched to tap to display. Screen resolution switched to FHD+ .
Please tell me if it's normal?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Your cell signal seems relatively poor. This can drain battery, even if you have wi-fi on. As a test, try turning on Airplane Mode, then turning wi-fi back on, and use the phone for the better part of the day on wi-fi only. (I think you can still use wi-fi calling with cell radio turned off.) Does the battery drain persist?
Toshiv Goyal
14
Hi thank you so much. Will just try it out, though I'm not sure whether with airplane mode , WiFi calling will work because it needs VoLTE , I guess. Thank you so much for help.
Toshiv Goyal
14
Toshiv Goyal
14
Can be better , also it will need about 7 to 15 days learn your usage pattern to adjust
Ok ok, got it. But i will try switching it to one sim or may be put my sims in another phone and use this one with wifi only to see the battery since the drain could be because of the phone signal being poor
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,172
113
You could try that, are the Sims from different carriers?
alexpall
