New Samsung note 10 plus battery drain. Plz help! Plz
Also attaching a screenshot of Gsam battery app , if that helps determining why is the drain thereView attachment 329533
In general, it's more helpful to see the battery stats after the battery has gone from 100% down to about 20%, to get a better idea of what's using battery over a longer stretch of time. We still haven't ruled out poor cell signal as a cause.
Ok got it. Like you suggested , I'm using the phone only on WiFi and put the sims in another phone. Will update the screenshot at 20% of Gsam like you have suggested.
Thank you for your help.
Hi there. Your usage is similar to my international S10+ with dual sim. These exynos chips are not very good for battery life and I think you are having the same issue as me. It may get better as your usage is learned by the phone but my settings are the same as your and your battery life is similar. The US versions are so much better on battery life.
Yeah, that's what I am also learning as I am reading through about this problem. Don't see much of a solution as well for this
Something else to keep in mind is the kernel and OS are still in a setup process. It can take up to a week for battery life to level out.
pamatika
