There shouldn't be any problem to upgrade now. The process will be done one step at a time, so it will take some time. The only thing you should be aware, is the fact that after upgrading there is a small chance you'll loose connectivity with you car's Android Auto. I have a Tab S6 on Android 11 and it doesn't connect to my car's display through AA.
