amyf27
It did with me at first as well but getting used to it. I like the double tap screen wakethe power button on the left side is bothering with my OCD.
Maybe you should rescan to get the whole finger. You also have to make sure you're pressing down hard enough. Other than me remembering that it's higher up than on the S10+ it's been really spot on and faster than my S10+.So far for me the FPS is total trash never works correctly
Hi, I got my Note 10+ 4G yesterday.
Just noted something weired.
When I take a call ( normall call or WhatsApp), a small area right to the front selfie camera slightly flickers, untill the call stops.
I'm wondering whether this is a fault.
Does your phone do it too?
Picked mine up a short while ago at the Ups hub. Going through Smart Switch now. Activated with no issues on Sprint-swapped my number form the Note 9.
loving it more each day. sounds stupid but it's a fantastic phone.Wow, that blue looks super nice. If I didn't already have a note 9 blue one then I would have gotten this one.
I personally think I'm gonna send mine back. For me it's not an upgrade over my Note 9. It is extremely similar with some downsides; the move of the power button, the garbage fingerprint sensor and the loss of the ability to unlock with the home button mostly. The only upgrade for me personally is the addition of the reverse wireless charging.
You can zoom out to fill the video full screen, by the way FYI it's the same behavior on S10+ in terms of symmetry because of the aspect ratio of the new Samsung infinity display starting with S10. If you don't like it on Note 10 then you won't on S10+ as well.Im not gonna lie, its pretty meh for me right now.
I never knew how much I would miss the headphone jack, I was going to get the galaxy buds, but I hear that while they are good for music, they are terrible for calls. I can deal with all of that though.
What is really getting me is the symmetry of the phone while using the internet in landscape mode. The top part of the screen is black and I can't make the nav bar disappear. Not only does that make it look off center, but it looks rounded on the left side and square on the right. I might just end up shipping this one back and either saving my money and keeping my note 9 or getting a S10 Plus.
You do realize that you can do the one move unlock with the n10 too right?it was a passing thought for me too. I hate that fingerprint sensor. I like the way it worked on the note 8. I am going to keep it but still going to have to figure a way to make it work for me without the frustration of having to turn on the screen then use the finger sensor.
I know I mentioned it a couple of times already, it was very convenient to place the finger over the scanner as I pulled the note 8 out of the pocket. it would be turned on and unlock by the time it was in front of me.
This is unacceptable in my opinion such an expensive device the FPS should work as advertised.The update Wednesday night helped the fps a lot. Still not perfect, but I can generally get it to work within a couple of tries.
