KupKrazy
Also, if you back your photos up to Google Photos, it also backs up the motion part of the photo as well. They added this feature earlier this year after having supported iPhone live photos for a long time.
Only if you leave it on "high quality" setting. I set it to "original quality" and it doesn't reduce anything but it does use your Google Photos space as opposed to being unlimited space. Kinda amazed a lot of folks dont realize that. Just go into the Google Photos setting to change it.it also, apparently from what I've read up on, reduces quality and file size. no thank you.
It's free backup. And the high quality unlimited backup is more than enough for 90% of people. Again, let's not forget, it's FREE. you want original size backup, you can subscribe to Google cloud and pay for that.Only if you leave it on "high quality" setting. I set it to "original quality" and it doesn't reduce anything but it does use your Google Photos space as opposed to being unlimited space. Kinda amazed a lot of folks dont realize that. Just go into the Google Photos setting to change it.
Yes, you can resize the floating Gboard until your heart is content by dragging the corners.thanks. I need the keys just a hair wider. is there any way to do that? also, I never found the setting in gboard to do what the Samsung keyboard does.
Tap the G logo on the left, then the three dots menu on the right, bottom right option will be floating. There's a tab at the bottom of the floating Gboard you can hold to move it around and if you drag it to the bottom of the screen it will dock there, regular style
Hhmmm.... If you choose the theme and turn in the border slider does that help?thanks, but that didn't help key width. when I first installed gboard on Note 10 it was white and the keys were wider. I chose a theme and got narrower keys. need to find that first keyboard and theme it if possible. thoughts?
Hhmmm.... If you choose the theme and turn in the border slider does that help?View attachment 309635
thanks. but like Samsung, I don't trust Google at all. don't want them handling my pics or my docs
So you run the phone without a Samsung or Google account? You don't use any of the Find My Phone tracking that Samsung and Google provide?
Definitely a cool feature! So glad you are enjoying it!
