Love This Device/Coolest Thing Yet!
I swear the Note 8 had a picture with background sound. That is not available on the Note 10 is it?
While the image is playing tap on it and slide your finger left and right to go frame by frame. At the top you will see capture. It will take that still frame and save it. Good for if someone closes their eyes during a picture, you can move it back a couple frames to where their eyes are open and save it. Just an fyi if you didn't already know.
thanks. I missed this tip when you posted it.
is there a way to save only one of the parts of the motion photo, extract it as a separate photo, if you will? thanks.
Quick Measure
iPhone can do the same but for a much shorter duration.
Yeah its a pretty old feature. The S4 use to be able to do it but I forgot what it was called. Then I believe the iPhone 6 or 6s got it.
Resizing keyboard. Never checked this on note 8. Now it is super easy with one hand swiping or typing.
sa1234
