For such a luxurious phone the calculator should have Memory Store (MS), Memory Plus & Memory Recall functions. Both for the simple and especially the scientific modes. I find the lack a surprising oversight by Sammy.
I use "AirCalc" when I plan on doing a quick calculation or need another app running at the same time because it is a floating app. When I am doing more and may need memory I use "Easy Calculator" It not only has memory but it has several memories (don't know it may have unlimited memories) meaning you can save a number to memory and then same a different number to memory and recall which ever one you want when ever you want it. then when I need a formula I switch to "MyScript Calculator" it is a hand written calculator. So you can write with the s-pen like on paper your formula and it gives you the answer. https://play.google.com/store/apps/details?id=com.myboyfriendisageek.aircalc&feature=search_result
