Note 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.
mib1800
59
Since installing this my device started over heating......did this happen to anyone else out there?
My phone runs cooler after setting it to 96hz.
I use the adb method to set max value so the VRR still works. Using the app will fixed to 96hz.
Now I touch screen, it goes to 96hz. A moment later it drops back to 60. Playing yt, it drops to 48hz.
Hermes Hidayat
2,617
38
in order for it to work,you must set to Adaptive.then press the 96hz toggle.if set to 60hz,no matter how many times you press the 96hz toggle it wouldnt change.
JellyBelly474
115
Can you please tell me how to set my phone to adaptive as I'm confused and don't understand? I have downloaded the app to my S20U Exynos but nothing changes but when I go into the app and click on 96hz. I'm using medium power saving.
Screenshot_20201015-224217_One UI Home.jpg20201015_224426.jpgScreenshot_20201015-225615_S20 Refresh Rate Control.jpg
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,590
6,174
113
View attachment 327823View attachment 327824View attachment 327825
Hi,
Just uninstall the app and go into settings>display >motion smoothness leave in adaptive. Not any power save mode other then optimized or high performance will turn it off unless you go through bixby routines as there a thread for that .Screenshot_20201015-183917_Settings.jpeg
JellyBelly474
115
Hi,
Just uninstall the app and go into settings>display >motion smoothness leave in adaptive. Not any power save mode other then optimized or high performance will turn it off unless you go through bixby routines as there a thread for that .View attachment 327827
Thank you mustang for your quick reply. I have looked at at my settings but I don't have adaptive, only high and standard. Don't know what to do. I'm back on optimised battery. I don't use Bixby routines.
Hermes Hidayat
2,617
38
thats wierd...my N20U has Adaptive and Standard...
AndroidFanboy8
690
179
43
That's awesome! The CPU started heating to the point I had never felt before. Still not sure why this happened.
