Sprint doesn't allow you to use their Call Screener app on an unlocked phone, it wasn't that good anyway. Will the T-Mobile one work or does someone have a better option I don't mind paying for something if it works well?
mustang7757 where did you find that? Sprint doesn't allow access to their app called "Sprint Call Screener" to unlocked phones.
That was in phone app settingsmustang7757 where did you find that? Sprint doesn't allow access to their app called "Sprint Call Screener" to unlocked phones.
Yeah the unlocked version have this , works pretty good.Thanks I just found it I had no idea it was a built into the dialer.
No, I have hiya enabled on my unlocked with sprint sim. The carrier version had a standalone app. I think that's what he is missing. All the features that app had are enabled though anyway in your call log if you have hiya enabled.Sprint blocked this ?View attachment 325524
Yeah all unlocked models should have hiya , the carrier i believe your right should have their own .No, I have hiya enabled on my unlocked with sprint sim. The carrier version had a standalone app. I think that's what he is missing. All the features that app had are enabled though anyway in your call log if you have hiya enabled.
