So when I bought my Note 20 Ultra, it came with a pre installed screen protector. Everything was fine until the next day where i noticed dirt/dust under the screen protector. I tried to remove the dirt but instead it got worse as the provided screen protector is just a piece of plastic.
So i took it off. Used my phone with the screen naked for around 1 month(no issues with FPS or input) . Then i bought the Rhinoshield Impact Flex screen protector. And i noticed that FPS seems to be slower and the phone doesn't pick up my touches at times(i did turn on Touch sensitivity).
So finally i decided to remove the Rhinoshield Impact Flex and go naked again.
But im wondering, if i take good care of my phone, will the screen be scratched?(i never put my phone anywhere with something else) i have an OtterBox Defender Pro installed. And it mostly stays in the holster with the screen facing in.
I do have 2 hairline scratches . 1 to the left of the front facing camera and the other to the right(caused by a Precision cutter which i used to make the Rhinoshield Impact Flex fit).
So its safe to go naked as long as i take care of it or do i need 1?
