unfortunately the majority of these will not work for your NOTE 4 if you have it from Verizon. way to screw us verizon. they said the reasoning for moving the microphone on the bottom over slightly was they thought it was a better design for function but that means you have to buy your case from them to get the mic holes to line up right.
Anyone with a Ringke Fusion clear case, how is it doing with the phone's aluminum sides? Any scratching?
I am someone who loves thin cases and I just got a tech 21 case and love it. It's slim and sleek. Would def recommend giving it a try
Tech 21 is up there at the top. They make a consistently great product.
yes I was torn between the Tech 21 and the Otterbox because in the past Otterbox has won. But this time I def love the protection of this case and the slimness
If it doesn't work for your phone I'll be happy to buy it from you.I just bought the tech 21 case for about 50 dollars. I completely forgot about the verizon issue. Did i just wast 50 bucks?? :/ Will the mic still work on the verizon note 4 with this case i bought. I bought it directly from tech21, because i needed the clear one. Thanks!
This might sound stupid but I'm guessing you didn't buy it from a verizon store lol
