Best thin case for Galaxy Note 4?
Wait, what is that Samsung labeled case on the left?
Here is a link, I think it is Samsung's OEM product.
Galaxy Note ® 4 Protective Cover, BLUE
It comes with blue or black.
It is about as thin as you can get and have a small lip for the front screen and rear camera. to protect it while laying flat. The website photo makes it look a bit bigger/thicker than it actually is. Not sure how much drop protection it will provide, but it would be some.
Re: Best thin case?
$12.99 from Amazon. I love it for the price.
What screen protector do you have and where did you get it? Who is your carrier as I have read some SP fit phones differently?
Its super thin, hugs the phone real tight - ZERO gaps anywhere. Has reinforced sides (Ill try to take a picture later to show that part of it off). It has just the right amount of grip. I gauge this by placing it on the passenger seat in my car (leather) and driving around town. If it doesn't slide around, it's golden. This one doesn't move much.
Some 'self healing' jobbie from the same company. So far it refuses to scratch. It has a bit of an odd feeling to it - almost like its thick plastic - you can literally push on it and feel it give. However, it is crystal clear and has zero input problems with either my fingers OR the stylus. Again, I highly recommend these guys. I have always been an Otterbox fan, but not so much now.
Is it hard to take off and put on? That's my only gripe with the UAG case.
Have a Spigen neo hybrid, Looks and feels great but adds a bit of weight and a slight extra width/bulk. Actually use it with dust plugs for the headphone and charging ports, May seem like overkill but I work in a warehouse/diy environment which can get quite dusty! Was never fun poking out dust from my old S3.
Received my Rinkge Fusion today, Love it! Very slim and and well fitting, Adds hardly any noticable bulk, With dust flaps for the headphone and charging ports, Win! Also to whom asked if the Neo Hybrid scratches the phone, No it doesnt. I think only the hard cases cause scratches not the TPU/rubbery ones.
Many great suggestions here. I use the $20 caseolgy case off Amazon. Good snug fit, Nice looking metal band, bumper, and leather texture on back for easy grip. I Love it, looks great and inexpensive. When this one wears out, I will get another.
Posted via the Next Big Thing, My Galaxy N4
Galaxy Note 4 Case, Maxboost® [Clear Cushion] Galaxy Note 4 Cas... http://www.amazon.com/dp/B00NAHOHFO...ag=hawk-future-20&ascsubtag=UUacUvbUpU4102806
Super thin profile and coverage around the edges. Rubber edges don't scratch the phone and the polycarbonate back protects the phone from normal wear and tear. Does not seem to be a drop friendly case, but I'll take my chances for the slim profile. Also, fits the VZW Note 4 perfectly.
Re: Best thin case?
unfortunately the majority of these will not work for your NOTE 4 if you have it from Verizon. way to screw us verizon. they said the reasoning for moving the microphone on the bottom over slightly was they thought it was a better design for function but that means you have to buy your case from them to get the mic holes to line up right.
The majority of these have been updated with an elongated hole to make room for the verizon model.
Re: Best thin case?
I am using the Ringke FUSION clear case. Yesterday my phone slipped off the roof of my car and CRASH onto the asphalt! Result = barely a mark on the case and no damage to the phone. Ringke wins.
Re: Best thin case?
Anybody using a wireless charging cover with a case, just wondering how good the connectivity will be with a case installed
Re: Best thin case?
I go for the Ringke SLIM case. Hardly know it is there, and is very good in the hand, not slick at all.
Ertiotka
