Best thin case for Galaxy Note 4?
I have 2 of these and love them..plus they are cheap. Rearth Ringke
Here's mine by Spigen
Sent from my SM-T700
Curious, have you had any issue getting it on and off? I like the one I got but it is so tight it's a struggle to get it back off again once it's on.
Haven't had much issue but yes it's harder to get off compared to other cases, which is a good thing to me it lets me know that it's snug. Try gently but firmly pressing both thumbs against the back of the case so as to "push out" the phone while your other fingers "peel off" from the lip. Just do it gently so it doesn't pop right out.
Here are the Samsung case and the Caseology together. The Samsung is less slippery and smaller. A 16th slimmer, same length, and rounded corners, make it seem dramatically so.
Don't know how that last pic turned upside down. Here is one more.
Do those metal cases kill the signal at all? I am guessing the little white things around the phone are for reception and those seem to cover the crap out of them. The sammy case looks really nice, might look in to that one
I have already bought several cases but this is the one im using. It's rubber so no scratching the phone,, so thin and clear.
NOTE 4,, GO BIG OR GO HOME!
As with some cases...does this make the device look bigger (bulkier is the term I think Im looking for)?
Thanks
It does but very subtle. Looks-wise it doesn't look any bigger, as in it looks slim and stylish, maybe because the case is so streamlined. But you will definitely feel the added thickness in your hand.
The Ringke Slim is the best!!! Covers the corner that most slim ones leave bare and exposed....look it up. Got in on amazon!
Re: Best thin case?
I went with the Otterbox and it's durable and thinner than I thought it would be.
I second the vote for the Tech21 brand. I have been a die-hard Otterbox supported until I had a chance to check one of these out. The guys at the store were putting their Note 4s in them and tossing them around the room. After getting to look at one, see how good of a fit it was, how tight the case is, the durability and material, reinforcement on the sides, etc, I was sold.
View attachment 147557View attachment 147558
What screen protector are you using?
Is this still considered a 'slim' case? It looks great either way! I just ordered the UAG case but haven't received it yet - wish I saw this case before I ordered! I missed it since it's not in Amazon yet, is there enough grip/texture on the back/sides or is the case a little slippery?
rido7788
