I've not used fleksy keyboard before. Have you tried SwiftKey? How do they compare?
I haven't install that yet but I'm planning if I can't adjust to this keyboard.
What phone are you coming from?
Thanks for answering questions. How's the screen in direct sunlight?
Kevin, can you give an opinion about phone reception? Maybe if you notice a difference from your previous phone in a weak location, or this phone being weak in a previous strong location. Most reviews don't elaborate on this much. Thanks for any info.
I noticed a not so smooth animation when I press the recent apps key. I'm not sure if this is android or samsung or nova's fault but it's just a very very little annoyance. I'm from ios and BB10 and animations on that OS are almost perfect. But still, this device is so beautiful and perfect for media consumption.
Grats Kevin!!
Can you use the S-pen stuff with Nova Launcher??
thanks!!
Hmm... I actually do have a question to OP:
How does the phone feel in your pocket in terms of dimensions and heft? Do you ever feel that it is kind of heavy (drags down your pockets/pants) in your pockets?
It's not heavy but it feels wide. I can't have it have it on my pocket while sitting on the couch or tying my shoelace.
So far so good. Very impressive hardware. And the screen really is the main attraction. The only con that I have is on the UI. Everything was so big! I hope someday, Samsung can give the option to modify it or allow the apps to run in 7" tablet mode. I think that looks better. By the way, I never had a chance to use the default launcher because I installed Nova Launcher Prime from Day1. I'm really impressed with this device and I hope it will continue to do so as I use it. The chamfered edges makes the phone attractive. This is really a great media consumption device. Very easy to put in the pocket while having that very impressive screen.
Can you comment about the speaker quality? I know it's in the rear but other than that has there been any improvement at all?
