My screen stay on unless I press the power button
Dagasm
3
Anyone else having a problem with their screen staying lit? For example after the battery fully charges or you don't physically press the power button to shut the screen off. I have my screen timeout set to 15 seconds, and after following instructions for someone that had the same problem with a S5, I turned on developer options and made sure stay awake was unchecked. It hasn't made a difference.
*stays on
Make sure smart stay is not on.
I would look at your 3rd party apps then that have permission to keep the phone awake.
albertowalish
