Androidprodigy
Imo clean master is good for cleaning cache, but when it comes to freeing up RAM, it is pointless.
Concensus is pretty much 'Dont use it!' So I guess you and I need to go to AA meetings to stay away from Clean Master and all apps like it! LOL!Definitely a good question
I clean cache with clean master every other day. I installed an app called spec device but deleted it that same day last week. Pulled the battery and it's helping a bit. Concerning that a phone that is a month old is already acting up
This same exact thing happened to my phone in the first few days I had it, and I had to do a battery pull as well. I also discovered I had a Bad SD card after that as my battery was draining horribly and IndexService was going non stop. After removing SD card. Neither problem has happened again. My phone has been perfect since.I had a similar problem a few days ago and I get installed anything new. Everything started slowing down and grinding to a halt. All of a sudden my screen just froze. I tried a long press on the power button to reboot but that did nothing. Pulled the battery and restarted and it's been fine since. Have no idea what caused it. Good thing a battery pull was possible.
