If battery issue, delete cache, fixed my battery issue
Deke218
1,333
187
63
Maybe but it takes about 30 seconds and it's increased performance on my prior devices in the past when doing it once didn't.
Deke218
1,333
187
63
Thank you wee one. Next.
In the past [prior to today] whenever I modded a device, I always cleared the cache 3 times [1, 2, 3] to ensure a clean device.
Maybe you're no aware that the ritual of "Clearing The Cache" may sometimes not entirely clear the cache clean on the first go around.
leegreg81
181
According to what?
Link me up with your source.
Wolvan
100
6
I'm impressed by the results. I updated to lollipop this morning and it was a bit laggy / hesitant after. Didn't want to fool with a full factory wipe as I'm on a trip visiting family with my son. But did the cache wipe and WOW. Everything is now super responsive, lag free. Have too see about battery, traditionally I've made it through one day and charge while sleeping.
Thanks for this tip. I'll do it to my wife's S4 and mother-in-law S3 when I get home. Hopefully help their battery performance.
Man, even my SwiftKey is super fast now.
Happy!
anon67808
197
So, I attempted this today. While booting into recovery mode and my up volume button was still pressed, I got the android robot on my screen with the message "updating system" or something like that. After about 10-15 seconds, it says "error" then the menu pops-up. I clear cache and reboot. Try again to see if that happens again and it in fact did however, both times I get the message that says cache delete complete.
Normal?
tivoboy
164
10
18
Normal?
yes, I get the same notification. At first I thought it was really trying to re-install the OS update, but it went pretty quickly to "cannot find" something, and then on to the cache cleaning, but it took like a second to do the cache clean.. shouldn't it take longer?
anyway, still operating at well below regular battery life, about 50% of previous battery life expectations. not sure what to do next other than a full reset and re-install everything. which is such a pia.
anon67808
197
I have so much on my phone since I don't even touch my laptop anymore. If it got to the point where I would have to either factory reset my device or suffer through sub-par battery performance, I'd suffer through the sub-par battery performance. There is no way I'm factory resetting my device unless it is absolutely necessary.
Rowlette
116
Here is a suggestion uninstall the largest programs then do a program cache cleaning(ccleaner, 360, there are many) then reinstall them. Next load a app like Greenify and setup to hibernate programs which sit in the background which really drains the battery then execute them when needed then again hibernate.
curti21
5
I was having trouble with this not 3 days ago. I searched for a good hour or two on Google, until I found this same thread, only for the S5. The cache cleaning solution was also mentioned there, and bam. The battery life is back to usual.
For me it was the Android System that was using it all with "CPU Total" and "Stay awake".
fbcltd
Active member
Mar 4, 2015
37
thanks for this.... so much knowledge on this site.... my battery has never been better. another tip was using power saving mode (not ultra) and boom....36 hours of battery in normal use.
