Samsung Note 4 Not Charging Properly With Burned Micro USB Tip
I have a Samsung Galaxy Note 4 At&t version. Starting 4/17/2015, my phone has been not been charging properly. In order to charge, I have to push the charging cable up in order to charge (if you need me to clarify that please ask). I am using two genuine Samsung adapters, one of them came with my Note 4, the other from my Note 2. They are both original adapters. I have two micro usb cables that is charred up on the tip as you can see from the pictures below. The white cable is a genuine Samsung cable, original again, and the red one is a genuine Beats audio cable. The white cable and the adaptive fast charger is my primary charging devices. Because my phone wasn't charging right, I decided to try another cable and adapter to see if it was any different. It wasn't.
The part the worries me the most the the burnt tip of the micro usb cable (please use pictures below as reference). I do not know what is causing this, my phone has literally never been dropped or touched any water. Please help. If you need me to clarify something, please feel free to ask. Also if you want more pictures, I can take some more.
Thank you for you help and advice.
The link is below, sorry for the inconvenience, this is my first question here and Android Central does not allow me to post links.
mediafire.
com/download/9hnbnh5tcdb1g9t/Links.txt
mediafire.
