My Galaxy Note 4 will not boot up and is just going through boot powered by Android and carrier screen. How can I fix this?
A
AC Question
galaxy note 4 will not boot up and is just going through boot powered by android and carrier screen
i rooted my tmobile galaxy note 4 about a month ago and i noticied a lot of lag using so i decided to unroot it using super user and reboot to get it all working fine but this happened.
Josiah23
Q&A Team
Mar 22, 2015
405
Re: galaxy note 4 will not boot up and is just going through boot powered by android and carrier scr
Unroot using super user huh? Can you go into download mode? If so flash the stock rom using odin with your pc. If you choose to go this route then post back saying so and I can give you step by step instructions. (If needed)
Sent from Mr. Tech Man using Tapatalk
RandyRoyalty
